lashlee
You could, but for the rears once you get the caliper off all it takes is one nut (the axle nut) to swap the rear hub. Its up to you, and if the replacement has less mileage or better bearings it might be worth it.
didnt know that it just comes right off, well i guess it wont be so bad for the rear as i thought...ill look at mileage comparison etc then..thanks lashleeyes, you can. coupe to sedan does not matter. the only thing that matters is that you get the rear spindles and ebrake cables for disc brakes, if your car is rear drum. if you're already rear disc but in 4 lug, then you could just switch all four of your hubs with the 5 lug ones and required brake stuff.
so what i have done since my car is rear drums i took the rear knuckles, calipers and e-brake cable off of a 4 cylinder sedan and now my next question is i am about to take apart the 98 honda accord v6 coupe to convert mine to 5 lugs now will all my 4 lugs parts fit on his V6 since he is going to be selling the whole car to a junk yards and need the car to be on wheels not on the ground for towing
still new to this but is this just for a Coupe or would it work for a 6th gen sedan.
let me know what all parts I would need. very much appreciate the info.
