Choppa
France
Hello guys, I'm new here.
I'm from France and drive an 1999 2,0L Accord coupe.
I'm very interested in swapping 4 lugs to 5.
I have a question, on mine, I already have front double pistons caliper and 282mm brake discs, do you have the same on yours ?
subaz
NJ
Question, has anyone figured out (or know the size) of rotors that are the same size as the 4cyl rotors but in the 5 lug configuration? Reason for asking is, I want to do the 5 lug conversion but use my 4cyl calipers temporarily until I source the TL brembo calipers or the 2 piston legend calipers.
Try Civic EP3 Rotors - 04-05 when they switched to 5lug
Centric # 121.40056
vs Accord Centric #121.40039
They're 1.5in larger diameter so likely not but if you wanna try it, go for it. I think at one time someone found something that works but I can't remember what it was off of.
subaz
NJ
Ah, that will probably work. I'm going to give a try and report back once all said and done
