Totalimmortal
At this point, I'll only be covering the front mount since I haven't done the rear yet. First off is to jack the car up just enough to get under it with the jack a piece of wood. I don't think I need pictures for that. You are going to placing the wood between the jack and the oil pan to prevent denting.
I used a wicked thick piece, I dont think it has to be that thick but I wasn't taking any chances. Once that's done you will see your front motor mount right in plain view between the block and radiator.
On the right side of the mount you will see a bolt that goes completely through the mount, hence it's name the through bolt(17mm). Remove this first.
Now here's where I have to improvise a bit. Your supposed to remove the mount to frame bolts that actually secure it to the frame. Im not gonna lie, those bad boy's wern't gonna budge. You can see in the picture below two of the three soaked in PB Blaster, they still didn't budge.
I ended up removing the bracket that attaches to the block as those bolts(14mm) were MUCH easier to remove.
Make a note that the bottom bolt is longer than the top two. Also, the o2 sensor plug bracket is attached to this so remove that with a 10mm socket. I used some synthetic grease I had left over from my PSPEC short shifter install that I used to lube the mounts. they don't go all the way in and from what I've seen they're not supposed to. It's going to take some presuasion to get that bracket back over the mount inserts, so don't give up if it's hard to put back on. And below is the finished product right after installation.
They will settle in a bit, maybe move a centimeter or so outward after driving on them so don't panic. Overall, the job only took about 30 minutes and there is a noticeable difference in throttle response. The car does idle rough now, but I like it that way. Some people may take a while to get used to it, but once you do you wont notice it anymore.
