pyaarawala
long island, NY
I'm a n00b at this stuff to so I just have a question:
When you state compression, you state it in this format, XX:XX:XX. What do each sections mean? My car (F23a4) comes stock 9.3:1 according to the 6thgen general FAQ. Why is it that the lower the compression, the better? And by lower, you mean that it goes from 9:3:1 to 8:3:1 or something? Also, you said that increasing the combustion chamber, and lowering compression makes the car faster. How does the combustion chamber increase if the cylinder can not expand?
Also, what's boring and sleeving?
I4 CG5
Fargo, ND
^^You want lower compression if you have a turbo and higher compression if your engine is N/A
BadgerType
Resident ***hole
SW FLA
question for our Engine God, Greg
How much hp is gained when switching to a dry sump system?
how much boost can our stock sleeves hold? as in actual test, not speculation
what engine break-in practice do you recommend for a newly built engine?
Do you recommend lightening the crank for mid-high boost applications?
Sythenic or sythentic blend oil for our engines?
best way to raise the rev limiter?
i shall have more for you greg
you mean, xx.xx : 1
higher number = higher compression, higher cylinder pressure before ignition
lower number = opposite
ex: 6.0:1 the volume of the combustion chamber at BDC is 6x the volume at TDC, etc...
too many factors involved for something thatno one in their right mind does
there is no answer to that question. boost has little to do with the factors that cause sleeve failure
drive it how you will be driving it
less weight is always better
synthetic is always better
reprogram ecm, but by the time the engine is ready for the rev-limiter to be raised, it probably also needs more than a piggy-back should be doing
Roadrage
POPE AFB/ FT. BRAGG
okay question for greg,
How many teeth does our camgear have, For an A5, tried google got two different numbers, one says 40 and another says 37, hopefully u can help. thanks in advance
LoL - stop asking me specifically.
No idea how many teeth our cam gear has. The best I could do for you is count my Skunk2 cam gear.
BadgerType
Resident ***hole
SW FLA
usually 8% increase through tires
boost has alot of factors with our sleeves. i think it is 32lbs
it was a new age (hard) or old age (easy) break in question. i plan on doin the new age break in
tru, but so many factors can cause the engine to fail, i wanted to hear his view
yeah, i ran out of questions
im not talkin removing the rev limiter, but raise the redline so i can safley run 8k every shift
