Discussion in 'Engine & Transmission Mods' started by BlkCurrantKord, Oct 15, 2007.
  1. BlkCurrantKord
    9,312
    41
    Sep 7, 2005
    LoL - Well umm...not really sure what to tell ya cuz I'm not sure what it is your asking. The stroke is how far the rod journal is extended from the main body of the crank. In our case its 97mm, in the case of H22's its 90mm.
    Knife edging doesnt increase or decrease stroke. It narrows or "knife edges" the journals on the crank so that it cuts through the oil in the pan more efficiently w/ less drag.
  2. BlkCurrantKord
    9,312
    41
    Sep 7, 2005
    If I can get Drew or someone to come over I'll take some pics of this stuff to better explain it. Cuz I've bascially got an entire bottom end of an engine to work with.
  3. DarkSideAccord
    DarkSideAccord nadeshiko fobz ftw..
    37
    17,828
    26
    Sep 19, 2005
    wat's a rod journal? :thinking:
  4. BlkCurrantKord
    9,312
    41
    Sep 7, 2005
    The connecting rods are connected to the crankshaft via the rod journals.
  5. xci.ed6
    xci.ed6 Well-Known Member
    2,909
    8
    Sep 5, 2007
    knife edging reduced the weight and drag on the counter weights, and has nothing to do with the stroke.
  6. xci.ed6
    2,909
    8
    Sep 5, 2007
    The crankshaft should never touch the oil in the pan. There is a heavy oil mist in the crank case from oil coming past the main and rod bearings though.
    It is done to the counter weights, not the journals.
  7. HandoEX
    HandoEX Well-Known Member
    39
    538
    Sep 6, 2005
    Fargo, ND
    What do you guys consider the weakest point of the f23's bottom end?
  8. xci.ed6
    2,909
    8
    Sep 5, 2007
    I've got a D16A6 disassembled on my bench...If I get time I may take some pictures, I have a load of stuff to sell on ebay anyway.
  9. turboputz
    turboputz Well-Known Member
    394
    Sep 4, 2007
    The District
    Well for basics, the rods are connected to the crank and as it spins it moves them up and down. The crank determines the stroke. The stroke is how far the distance is from when the piston is at its lowest position to its highest. To my knowledge the major modifications made to the crank are: knife- edging, micropolishing, and balancing. The goals of these I believe are to reduce rotational mass, reduce bearing wear, and ensure the crank is balanced so that it doesn't get a wobble at high rpms.
    I do not know about mods to the crank that would increase stroke. That is most often done through the use of an aftermarket stroker crank. B16's are stroked to 1.8L 4G63's can be stroked to 2.3L, etc.
  10. BlkCurrantKord
    9,312
    41
    Sep 7, 2005
    I know this, just trying to answer one too many questions at once.
Share This Page
