F23 oil consumption
9450erick
los angeles
mine also burns about 1/2 a quart every 2 weeks. i think its my rings but repairs would be a lot more costly
finch13
Twin Cities, MN
Why is everyone subscribing?
I know my engine is worn... I beat the piss out of it and it has 225k on it. That's why I'm rebuilding an F23 and swapping them this summer.
hotaccord243
SW suburbs, MN
Yeah sometimes the most cost effective method is just knowing when and how much oil to keep putting in the motor. Heck, i did it for a long time too.
loanaccordr23
maryland
mine usually burns about a quart or so every 3000 miles... just changed my oil this morning and it was about a quart low from being full... i got a little over 180k miles on my motor...
turbo_911
State College, PA
Lol because you know some good info :) some people might need it hehe
MARSHIN2
Chicago
I don't really burn any oil. When i do oil changes ill usually pour back the used oil into the oil bottles i just poured in, and ill be missing just a bit. but then again my engine has only 98K on it so far =) , the only thing concerning me is the tiny metal specks ill see sometimes...
9450erick
los angeles
my car has about only 95k on it.
i do beat the **** out of her. but she luvs it(i think)
as long as i keep her maintained shes happy lol
Totalimmortal
Westminster, CO
Now this is coming from owning my galant, but metal specks in the oil is normally a rod bearing getting chewed up. Saw the same thing in my oil after my bottom end seized
jwong512
Socal 626
I'm around the same. However, my valve cover seems to be leaking oil so I'll change the gasket and redo the seal at my next oil change. Hopefully that should fix the problem. I'm assuming my car should be burning maybe about 0.5-0.8qts with a fixed seal. Usually, when I do an oil change I let the car hang for a good 30 minutes to drain out as much oil as possible. I would do it longer but I don't have the time to just let the car hang.
