Oct 6, 2009 #11 Russianred Snail Spools You! Joined Jan 10, 2007 Posts 9,455 Reaction score 50 Location Southern Maine [207] Bumpin'
Oct 6, 2009 #12 J jaron001 Well-Known Member Joined Jan 12, 2009 Posts 880 Reaction score 2 Location camden nj is your pin in the correct location at the ecu. i know a few obd2b hondas have to be changed
Oct 6, 2009 #13 J jaron001 Well-Known Member Joined Jan 12, 2009 Posts 880 Reaction score 2 Location camden nj you can try gettin an whole f22 IM also
Oct 7, 2009 #14 Russianred Snail Spools You! Joined Jan 10, 2007 Posts 9,455 Reaction score 50 Location Southern Maine [207] I'd rather try out the pin idea.. How do I tell if my pin needs to be repinned? Where to repin it, at the harness, or at the ECU? Which wire..?
Oct 7, 2009 #15 finch13 Well-Known Member Joined Apr 2, 2008 Posts 5,025 Reaction score 41 Location Twin Cities, MN Well, in Connector B at the ECU, there is a BLK/BLU wire at Pin #23. I'd imagine the F23 3-wire has a power, ground, and signal (BLK/BLU from ECU), whereas the F22 2-wire is just a signal and ground. Here's the pinout diagrams:
Oct 7, 2009 #16 finch13 Well-Known Member Joined Apr 2, 2008 Posts 5,025 Reaction score 41 Location Twin Cities, MN If you want an F22 upper plenum, I think I have one sitting in my room with the 2-wire IACV.
Oct 7, 2009 #17 J jaron001 Well-Known Member Joined Jan 12, 2009 Posts 880 Reaction score 2 Location camden nj please save this to your hard drive because its linked from another site. that civic is ob2b compare the pins to your harness and if its different change them accordingly
Oct 8, 2009 #18 Russianred Snail Spools You! Joined Jan 10, 2007 Posts 9,455 Reaction score 50 Location Southern Maine [207] Thank you Finch and Jaron, I'll try that out. I don't see your picture though Jaron..
Oct 8, 2009 #19 J jaron001 Well-Known Member Joined Jan 12, 2009 Posts 880 Reaction score 2 Location camden nj see they took them down that fast lol
Oct 9, 2009 #20 finch13 Well-Known Member Joined Apr 2, 2008 Posts 5,025 Reaction score 41 Location Twin Cities, MN I rehosted his image:
