leak behind timming belt cover
lashlee
Knoxville, TN
I have the same problem. I replaced the crank seal during the last timing belt swap since that's where it appeared the oil was coming from but I still have the leak. I still had a drop hanging off of the bottom of the cover today when I changed the oil. I'd like some info if anyone knows where else it could be coming from.
Russianred
Snail Spools You!
Southern Maine [207]
Updates? My guess would be poorly seated seals, Mike. Make sure that that's where it is coming from. Check every suspect area.
mkdb89-02se
waller tx
i will update this as soon as i get back to my coupe i got a serious problem with my 6thgen sedan v6
fml i never catch a break lol
mkdb89-02se
waller tx
took top cover off of timming belt covers and took a peek inside
cldnt see all the way down but i knw its not the valve cover cam and doubt its the balance shaft
only conclusion is the crank since its the only one i didnt see
