Re: Morimoto Retrofit experience
HID in your highbeams?? I pity the sucker you blast with those!
Well, it really easy doing the Maxima corners. Just use a piece of cardboard as your template. Once you get a good enough template, place it over the corner and mark with a sharpie. Then demel away. It does not have to be 100% perfect but get it close as you can. Then epoxy these onto the headlights. Then you soften up the rubber edge protector by putting it in oven for 2 min. at minimum heat, then stick it along the edge of the corner lights. That's it! Acutally looking at my pics will give you a good idea how to do this anyway. I say the actual projector retrofitting was more difficult.
If you're gonna do it and have any questions, do not hesitate to ask me. Good luck man.
you should of done a diy on the maxima corners ....i still havent decided if ill be doing mine with the corners ...... that eventually i want the morimoto retros for my highbeams ....so maybe then
