AFAccord
You don't need diff maps for different situations. The only time you would need 2 different maps is when you are running a low-boost/high-boost setup.
Just because you have your map tuned for best performance at WOT, which is how any1 would assuming they are paying for dyno time, that does not mean in ANY way that you should have to let go of low rpm driveability. Changing the throttle input thresh hold for VTEC engagement in NO WAY changes the map itself. The only thing that would change is the RPM at which VTEC engages, depending on the position of the gas pedal.
You never lean out the ENTIRE map for gas mileage. When you are on the highway, you are at low load, so your low load map can be tuned for mileage, while the high load area for performance.
BINGO!!
