00AccordLX5spd
Are the connections at the battery clean and tight? I suspect since you are disconnecting/connecting you must have ruled that out already. I doubt it is the alternator because you said when you get it started it runs fine. If the alternator was going bad the car should die on you while you are driving. Places like AutoZone or Advance Auto Parts will test your alternator for free, so you could do that to totally rule out a bad alternator.
When it won't start does it try to turn over, or does it do nothing at all?
