The Car Audio FAQ
Discussion in 'Car Audio & Electronics' started by Wildman, Sep 5, 2005.
  1. Wildman
    Wildman Read the rules
    5,135
    26
    Sep 5, 2005
    Alexandria, VA
    feel free to provide logical information to be edited in for a better post, but comments in passing are pretty worthless.
  2. OneLoud00Accord
    OneLoud00Accord Well-Known Member
    63
    Jun 18, 2009
    Bourbonnais
    This is from an article I rather enjoy... it took me a few readings to understand though lol
    "There's a common misconception out there that heavy woofers must be "slow", and light woofers must be "fast". If a woofer A's moving mass is higher than woofer B's, then woofer A is probably going to be sloppy, or slow and inaccurate. Can't keep up with the bass line. Woofer A simply can't respond as fast as woofer B.
    There's also this concept that the "acceleration factor" (BL/Mms) is an indicator of woofer speed/transient response. High BL, combined with a low Mms, should give great transient response, right?
    Well, on surface these might sound like logical assumptions. However, they are in fact incorrect! More to the point, moving mass has precious little to do with woofer speed or signal response! And we'll prove it...
    Go back to good old Newtonian physics... We're going to start with the famous law:
    F=ma (eq 1)
    Or force equals mass times acceleration. Anyone who's been through introductory physics (or watched a bit of PBS) should be familiar with the equation above. It's pretty much the bedrock equation of Newtonian physics - it's number 2 of the Big 3 Newtonian equations (the first being about interia, and the third being about complementary/opposed actions).
    Now, let's look at a loudspeaker... What do we have? We have a coil of wire which creates an alternating magnetic field which interacts with the static magnetic field in the gap (see our page on DVC subs for a bit more information on this). How does the alternating magnetic field of the coil come into being? Well, the magnetic field is created by passing a current through the voice coil. As the current through the voice coil changes, the magnetic field created by the coil changes. This field interacts with the static magnetic field of the permanent magnet, and you get a force - the cone moves in and out. Just like two permanent magnets will attract/repel each other depending upon how they are oriented. And a bigger current means more force. Just like bigger/stronger permanent magnets mean stronger attraction/repulsion.
    Additionally, what if we make the field of the permanent magnet stronger? Well, that's call the B field in the gap. Increase B, we increase the force as well. Or, what if we could somehow make the magnetic field from the voice coil stronger? We can - increase the number of turns of the voice coil (increase the Length of the wire in the gap). Guess what - in both cases, we increased the BL of the speaker (yes, this is the BL of the T/S parameters - now you know where it comes from!).
    Now, let's go back to equation 1... Let's define each of the terms in that equation so we know what we're talking about:
    F= Force
    m = mass (moving mass)
    a = acceleration
    So, what is the Force (NO Star Wars jokes, please!). From above, we see that the force on the cone is the motor force factor (BL) times the current. So, let's rewrite equation 1 in these terms that are applicable to the loudspeaker:
    BLi = ma (eq 2)
    So, the Motor Force Factor BL times the current i equals the moving mass of the driver m times the acceleration of the driver a. Note that we have italicized i and a. There's a reason for it!
    Now, back to the original question - transient response of a driver. What is transient response? Simply a measure of how fast the driver can respond to the input signal. That means that - inherently - there is a time dependency on the driver. How much TIME elapses before the driver responds. So, let's look at equation 2, and cancel out all terms that are not based on time. After all, if a quantity is time-invariant, then it won't affect time-variant effects like transient response (think of this as a simple offset).
    Or, to put it in an analogy, does the 1/4 mile time of a vehicle depend upon where you start? No, the distance over which you measure is still 1/4 mile. So whether you start in front of your house and go straight 1/4 mile, or motor on down to the dragstrip and go 1/4 mile doesn't really affect the car's 1/4 mile time. The 1/4 mile time is strictly dependent on how fast the car can accelerate from a dead stop over a 1/4 mile length.
    So, looking at equation 2 we see that:
    BL is time invariant, assuming small excursions (assume an ideal motor with a flat BL curve; I know, most drivers don't have that, but assume that it does, like our XBL2 enabled motors). So BL is essentially a constant.
    i is the current into the driver (we used italics to indicate a parameter that is time-variant). This is the music, or test tone sweep, or whatever signal is coming from the amp. It's an AC waveform so by definition it changes with time.
    m is mass. Well, if the moving mass of the driver is changing as you operate, you've got big problems! The weight of the cone, dustcap, former, voice coil, surround, and spider are pretty much fixed. The don't change either. So m is essentially a constant.
    a is the acceleration. This is what we're after. After all, the rate of change of acceleration IS the transient response - it's what dictates how fast the driver can change speed, which also means it dictates how fast the driver can move from position to position. And note that it's in italics, too. After all, acceleration in the time-variant parameter we care about here!
    So, let's rewrite equation 2, and replace the time-invariant parameters with a simple "C" to indicate a constant (a parameter that does not change with time):
    Ci = Ca (eq 3) or i :: a (eq 4)
    (note: the "::" symbol is the mathematical symbol for proportionality; that is, i is proportional to a).
    Interesting! This says that the change in acceleration of a driver - how fast it can change position - is strictly a function of the current through the driver. In fact, if you could make the current change infinitely fast, then the driver would accelerate infinitely fast, and we'd have infinite transients - zero time to change between states. Infinite frequency response.
    So, now that we know that current is the driving force (pun somewhat intended) behind driver acceleration changes, let's look at what limits how fast we can ramp current through the driver. Because if we are not restricted in how fast we can change the current, then we are not restricted in how fast the driver can accelerate - transient response is not limited at all.
    So, back to that loudspeaker model... A loudspeaker is a coil of wire wound on a former that attaches to the cone. The current flows through the coil, creating an alternating magnetic field that interacts with the static magnetic field of the permanent magnet. So, what could limit current flow? Well, what does a voice coil look like?
    How about an inductor? You know, those coils of wire (hey, isn't that what a voice coil is) that you use in crossovers? Guess what - a voice coil IS an inductor! In fact, an inductor stores its energy in the magnetic field (as opposed to a capacitor which stores its energy in the electric field). It is this magnetic field of the voice coil "inductor" that interacts with the permanent magnet field we talked about above. Hey, a loudspeaker is an inductor hung on the end of a cone in a static magnetic field!
    So, what about an inductor will alter the way current flows? Well, inductors don't like to have the current flowing through them change. They like to hold the current constant. They will allow you to change the current flowing in them, but the bigger the inductor (or, the higher the measured inductance) the longer it will hold the current before it starts to change (I'll leave it to the reader to go research inductance on their own, to learn why this happens).
    So, the voice coil is an inductor. And we see that inductors don't like to change current. But we also see from equation 4 above that we need to change the current if we want to change the acceleration. So, the voice coil doesn't want us to change the current. How good is it at holding the current? Depends upon the inductance! The higher the inductance of the driver, the longer it can hold the current flowing through it. Which means the more time elapses before it starts to respond to the amplifier's applied voltage. Which means we have slower transient response.
    Guess what - we just answered the original question! It turns out that transient response of a woofer is not a function of the moving mass, as is commonly espoused (one of the most infamous audio myths). In actuality, it is based upon the inductance of the driver. And the greater the inductance, the slower the driver - the lower the transient response."
    There is a graph and measurements that follow the above information. I need to host the image, however, in order to show it to you. The information / text won't really help without the graphs. The final paragraph of the article reads:
    "Mass isn't the problem - inductance is. So if you want faster transient response, ignore that moving mass parameter that some manufacturers push - look at the inductance! And if they don't list the inductance, ask yourself why - is there something they don't want to show? Inductance is the key to driver transient response - ask for it when transient response comes up!"
    Im not sure anything you can edit in I just dont like that the sub section says that larger woofers are slower when they are not at all. That is one of the most common audio misconceptions. And as eggy said there are several amazing small drivers that will own larger subs of lower quality, but thats kind of common sense I suppose if you compare a 12" fi btl to an 18" fosgate punch series its not even a question.
  3. Wildman
    5,135
    26
    Sep 5, 2005
    Alexandria, VA
    I skimmed the article and will have to read it again later, and will be happy to correct any misinformation. Although, I tried to make it pretty clear that there were no universals in comparing one size to another though, that the quality & box also makes a big difference. This guide was basically written for someone who is probably walking into Best Buy with very limited info.
  4. OneLoud00Accord
    63
    Jun 18, 2009
    Bourbonnais
    Haha no problem man. I would just hope that while several people here might have very limited knowledge we can spread correct knowledge that will benefit everyone as they learn. Car audio is probably my favorite hobby although im not a professional.
  5. arise257
    arise257 Well-Known Member
    137
    Jul 15, 2009
    Washington DC
    Any recommendations on reducing rattling? You know when you crank the bass and can hear your car vibrate...
  6. eggyhustles
    eggyhustles Well-Known Member
    703
    Aug 9, 2008
    tri-state
    Sound deadening.
  7. ryan s
    ryan s they dont think it
    17,504
    34
    Dec 27, 2005
  8. botang47
    botang47 Well-Known Member
    98
    Apr 5, 2009
    savannah, ga
    For me, it was the entire trunk lid. I unscrewed those rubber stoppers about half a turn, allowing the lid to seal tighter. It helped alot, but I've never seen a trunk that didn't rattle even a little. Sound deadener(sp?) would help even more by adding extra mass.
  9. cg6boi
    cg6boi Well-Known Member
    32
    1,051
    Dec 17, 2006
    SacTown the MacTown
    put a sponge under ur license plate...haha worked for me! i will say wildman did a great job on the faq, some info can be expanded on but all in all im sure this has helped hella people out, HIGHFIVE wildman!
Share This Page
