Painting the engine bay the same color as the car... white.
Here's the latest update:
Ok.... still waiting on the oil pan
Today I unpacked the exhaust, cleaned it up, and painted it flat black with some hi-temp paint I had. It's aluminized steel in the middle section (that's why I painted it)... the Apexi N1 muffler and TRUST (modified) downpipe is stainless steel (the bottom of the downpipe has a steel flange though.
) V-band mount on the turbo, came already wrapped, and with a free o2 sensor from his Power FC Djetro. It has two bungs wired up for whatever my need. Not bad for a $400 USED custom exhaust that'll bolt up to my setup.
I also finally have all the parts I was waiting on to finish swapping bellhousings. The Z32 tail section and RB26 bellhousing bolt right up. This allows me to use the Z32's driveshaft, trans mount, etc. without any modification. It will just bolt right up.
The transmission has about 170k miles on it...and I was impressed of how great of shape it's in. (the previous owner ran redline MT90 in it after having 4th gear scratch's with Royal Purple.).
Also, you'll see below, the 4th gear synchro's are a little worn, which would explain why it doesn't scratch on my 3-4 shifts all of the time...just some time... the pedal just has to be pressed fully for it not to scratch. I'm sure this will slowly get worse.
Anyway, here ya go:
The final product, ready to bolt up:
Anyway, here ya go:
