A little update (no pics for this update yet)...
This weekend I got a few things done:
* Replaced rear main seal (used a KA24DE rear main seal from a 91-98 240sx USDM)
* Installed modified oil pan
* Wire tucked the fuse box in the engine bay (now located under the drive side headlight)
* Drilled out the welds and removed the upper radiator support (will go on later)...I had to do this because the engine is too long to drop in the car but the support will fit once the engine is in.
Clutch showed up. 300zx N/A (90-96) 240mm 5 puck sprung clutch. 650 ft/lb holding capacity.
After some talking with a good clutch and flywheel expert (Greg Dupree at Specialty-Z in so-cal), I'm running the stock RB26 flywheel for my application instead of an aluminum one. These clutches eat aluminum flywheels for lunch.
More to come in a few weeks. I'm prepping the engine bay to paint it, but it's been so damn cold here in Texas that I don't want to risk messing up the paint because of the temperature. (I even have a heated garage, but natural gas "open flame" heaters don't go well with toxic paint.
