I think you have the wrong plug. That looks a lot like the part of the harness that goes to the fuel injectors.
If that's the wrong plug then which one is the right plug? Please give me something useful. This cannot be the injector plugs or part of the the injector because this plug plugs to the automatic sensors on a auto car. Please don't assume and give useless info.
I'm not trying to be rude but I'm just needing some helpful info and not a assumption that this is a inj plug because other people are curious on this too or will run into same issue.
Anyone know about a pilot bushing for the 5 speed swap? Anything I need to worry about there? just installed my new fly and pressure plate.. getting close!!!!
Blkcurranykord- FYI how can it be in lines when the coolant inlet is directly right there. And BTW your getting your panties twisted. As i stated i am not trying to be rude. Panties twisted lol. This guy. If u done the swap you would clearly know the cars underhood Inside out. Second of all I asked for help but got an poorly observed assumption. Its OK I got my ride starting no thanks to currantkord. . Thank the Honda accord 6th gen bible
BTW I didn't do nothing wrong. My harness just seems to be a bit different. Again poor assumption. You need to stop with the poor assumptions.
