DIY: Automatic to Manual Transmission Swap
Daproblem23
Atlanta
Hey all for some odd reason when I plug in my p13 ecu to my car it make car idle bounce from 1000-1500 the p28 is even worst but when I plug up the jdm Pcf ecu everything works fine problem is I have a 5 speed And can't use the jdm ecu any fix on my idle bounce
honda_egf22
utah
On the main trans plug I dont have the red, grey and black wires. I have a red w black stripes. Is that considered as the red wire. And I cannot locate the grey wire. My ride is a 98 4 door sedanand use to be ulev but now its using a non ulev engine but using ulev engine harness. Need help asap please
At this point - less information is key.
Post a picture of the harness plug that you're using.
honda_egf22
utah
I tried but they said I have to be a member for at least 7 days.
All wires I see are yellow, white, black, baby blue, brown, pink, light blue, blue w/ white line and black w/ blue lines and red w/ black line's. I know this is the main trans harness but no grey or red. Very doomed. I know their got to at least be 5 others who had this problem
honda_egf22
utah
Unless the diy instructions stated grey and red wires from the transmission harness on the transmission and not the actual engine harness.
SuperMidget
Edmonton, AB
AAHH! CAN'T WAIT!!
Starting my 5 speed swap this weekend :hide:
This thread still alive? I could use peoples input ...
honda_egf22
utah
This is my main big trans harness. It has a few of same colors as original posters pix but no red and grey wire. Anyone have the same issue as me. Unless this isn't the main trans plug on my engine harness. Help please. Someone has to have had this problem.
O.P. has this plug too and his plug looks almost like mines. Except no red wire or grey wire
honda_egf22
utah
<a href="http://s100.photobucket.com/user/punk_rock_korean/media/IMG_20130614_110621_189_zpsd69550e4.jpg.html" target="_blank"><img src="http://i100.photobucket.com/albums/m10/punk_rock_korean/IMG_20130614_110621_189_zpsd69550e4.jpg" border="0" alt=" photo IMG_20130614_110621_189_zpsd69550e4.jpg"/></a>
