Re: Going for a re-tune.... (updated 7/30/12 -- Dyno vid & info on Page 38)
I was actually thinking the L series might be better suited to your needs. He rates his in-house stuff in whp.
"Dyno tested to efficiently flow well up to 550whp."
Jason - That L series is practically taller than all of precision's intercoolers, but thinner and not as long. It seems like it definitely has the dimensions that will be needed for the airflow, and the price is what is selling me on it, know anybody that has used them before with high powere?
How do you like your clutch? I've been debating between the XTG6 which is rated way more than I'll ever need, or the XTSD like you have that's only rated to 385ft/lbs. I really want the smooth engagement of the full disc, but if I hit my 400whp mark, it'll likely be quite a bit more torque at the flywheel than the SD is rated for. I really wish we could see your torque numbers. How would you rate the XTSD for your setup? If you could go back, would you buy the same clutch?
I was debating on the two for the longest time as well, when I was planning on upgradinge. Of course I ended up with the SD and not the G6, due to drivability. But I absolutely Love the SD, nice and short engagement, (although not so bad as like a 4 puck/6 puck/twin disc like an on/off switch), it still has some smooth engagement as a less intense clutch but the strength of a xtreme pressure plate.
The clutch actually is holding up just as good as it does the day I bought it for sure. The down side to these heavy duty/extreme clutches are the slave cylinders and master cylinders are not made to handle the pressure, and since there are no "upgrades" for them per say, we just have to keep replacing them every year or two..... But overall a fantastic clutch. I'm sure i'll be upgrading to heavier duty clutch here soon for sure.
If I was to do it over, definitely would buy the same clutch no doubt. If I knew i'd be where i'm at know back then, I would of went more xtreme of a clutch so I wouldn't need to upgrade soon though, but who would've guessed?
Devin, I had a slow day at work, so I decided to plot the torque on your dyno chart. Assuming by your speed they did a 3rd gear pull, it seems to fall right on target with a ~6250 redline. (You're still using the stock cam?? That would be my very next upgrade next to the FMIC. I don't know how efficient that SC34 turbo is around your peak boost level since Precision doesn't provide compressor maps, BOOOO!! I'm also curious why the turbo doesn't spool faster, but that may have something to do with your lower compression.) I zoomed in to 300% when plotting and tried to draw the dots within -/+2 accuracy. Obviously its not scaled as well as the dyno could do, but it's close enough for government work (pun intended). Cheers.
EDIT: Also meant to ask where your VTEC engagement point is. That's not it there at 3300rpm, is it?
Jason -
- You are correct on the 3rd gear as it is the closed 1:1 gear on our cars and that is typically what I ask for.
- Still using the stock cam, which is one of the next upgrades on the list.
- 7200 redline is actually where it is at, but there's no need to go that high, due to loss of the power band.....
- I'm not too sure on the specs on the sc34 or compression maps either
- Vtec engages at 3300 you are correct.
That's probably pretty accurate, as that's similar to what the torque lines from the last tune that was done on the car. Well done! I appreciate it a ton! you rock!
On another note, the place I bought the battery relocation items are taking forever to get me the negative battery clamp, so i'm waiting on that and will get everything rolling in the right direction.
Jason - if you could let me know if anyone has experience with some of his intercoolers, and proven numbers that would help me a ton!
