Non-rice engine dress up?
talontsiawd
East Bay, CA
Wait... now does the tire foam clean off all the grease and everything? Also, what do you mean clean it by hand... just with a rag or something? And do you just spray the tire foam everywhere in the bay, or just directly on the engine?
What i do, take an entire can of tire foam, spray down the whole engine bay. That means the inner fender wells, any plastic, well, basically everything. Cover up your intake with a bag if it's exposed. Do it with your engine warm as well. Then, after half an hour or so, wipe it down with a rag, and just lightly spray it down with water. Only use a fine mist so you arn't getting into any electrical connections. Get most of the water off, start your engine (with the bag removed of the intake, or anything else you want to protect. Then you are good to go.
I've spend hours with simple green and other ways. This is so much easier, about 10 min of actual work, 45 min total, mostly waiting. Should look brand new.
zitro_pr
Puerto Rico
What is the best recomended product for clean and polish the diferent metal and aluminum part from the engine ?
I am interested to clean the diferents metal parts from my engine like .
talontsiawd
East Bay, CA
If you want to polish something to be mirror, it takes some sand paper, aluminum polish and half your life. Start at around 400-600 grit and work you way up to 1500-2000, making sure you sanded through all the scratches from the coarser paper. Then polish it up with aluminum polish.
If you have parts you just want shinny again but not mirror, just go over the part with fine steal wool and it it will look like new
