Fabian
Wat. Post pics of the back pad.
I'll have to get back to you about doing that cause I'm on my way to Florida right now and no way of getting a pic of that to show ya.
+15 - 25 = -10
So your wheels would effectively be 17 x 8.5 -10
These are 17 x 9 +38
To compare, your wheels will stick out 38 + 10, 48mm further, but are about 12.7mm narrower, half on each side, so subtract 6.3mm, ending up with 41.7mm. Your wheels will stick out 1.6" further than the ones in the picture.
In other words, they're going to stick out like a set of 13" daytons unless you run LOTS of camber, and probably some fender mods.
If you run NO spacer, they will be out 23mm further, again subtract the 6.3 for width, 16.7mm or 0.65 inch.
So maybe you can redrill the hub and rotors? I'm not sure if it would be safe though.
I just don't know where to take them to get redrilled and filled!! I'm working on finding someone that will do the work
