The "DOES IT FIT?(parts)" Thread
kamekaze89
California
Im new to 6th gen, question is does 00-01 coupe mud guards fit 98-99 coupe?
I know the fronts are all the same for all year and model but back bumper is different. Thanks!
98CG5
Richmond VA
Its probably been asked before but will the 98-00 coupe OE Optional lip fit on my 98 Sedan? I LOVE that lip and I dont want to settle for the "Type R" lip...
Akingkhan
Nor-Cal
Not with out modding it, but I think bayson r makes an oe rep lip for the 98-00 sedan.
Yes they will fit, they are the same mud guards.
luanster
SL,UT
So I have a 98 accord sedan and I tried doing a coupe conversion on it but the bumper doesn't sit flushed near the headlight-fender area. I was wondering if anyone who's done the conversion has run into that problem? If it helps, I got the 98 coupe bumper. I'm also asking because I want to get the 01-02 coupe bumper instead for the fog lights but not sure if it would be worth it if the bumper won't sit flushed.
Tra.Xenon
Roseville, CA
I found a CF hood for a coupe for about $200. Perfect condition. I have a 1998 Sedan, and I am planning on doing a coupe conversion from a 98-98 coupe. Will the hood fit on my sedan until I do the new bumper?
nine23
Groton, CT
there will probably be a gap between the hood and the bumper but it will fit! too bad you dont live closer i have a green 98 coupe bumper i would sell you
l1nd3n
Arlington TX
Wow! I read this whole thread and have learned a lot about what I am working on. Doing the 01' acura tl 5 lug swap to my 01' EX. Got knuckles with everything plus the 01' wheels for 500. The front looks pretty straight forward. I am a little curious about the back.
-Will the rear TL knuckles bolt up fine?
-Will parking break cable work?
-I also got the break booster and master from the TL. Do I need to use them?
-Do I need the proportioning valve thing from the TL?
-I read a couple times about multiple piston calipers that may go on this setup. Which one do y'all recommend?
Thanks guys. My first post. Had my 66k mile EXL manual accord for 2 months now. Took a year to find it but now...its on.
Glad to be here.
l1nd3n
Arlington TX
I searched and found an answer. The rear knuckle should be a direct swap. The other questions still apply though.
