hondatech03
You won't need it only if that motor was originally mated to a 6 speed manual transmission, otherwise you will need RichieV6's module.
if its just swapping some wires I can do that, or will it not work at all?
Why cant you use the ecu from a 7th gen 6 speed?
This would work if you were using the motor from a 7thgen accord. But the ecu and a 3.2 will not work together, because they are different motors.
Then you need to use the richie harness. The only way not to use a richie harness is if you get the wire harness, ecu, motor, and trans all from the same motor code/transmission type.
