EmMinODaGreaT
Its really not as unfathamable as you guys are making it out to be.
All you are doing is building a motor, upgrading parts so to speak so that they can handle making power when you need to.
You do everything you need to make 400 whp if possible using
stock head,cam,im,sensors
built bottom end,stock sensors etc etc.
retain stock ecu,injectors,emissions components so that when its time you can reinstall and pass.
You dont even have to disconnect a charge pipe, just drive a dont see boost so that a stock map sensor which doesnt understand boost will not wig out.
This is a doable feat.
Rods
Pistons
Supporting turbo and injectors
IC and piping
wastegate
turbo manifold
stock sleeves maybe w/ a block guard for good measures
head studs
balance shaft elim
With a stock ecu,stock inj, and just a turbo spinning but not creating boost the engine's efficency is going to increase theortically creating less emissions. Because it is not working as hard.
It can be done. If you like, I'll just slap on a tad bigger turbo, and show you what a stock head can do. and pass inspection.
Rods
Pistons
IC and piping
wastegate
turbo manifold
head studs
balance shaft elim
