It may not be as easy as I think...
BUT this is what I am thinking... changing the engine compression from 8.8:1 to say 8.5:1 shouldn't make much of a difference, the ECU will not be able to tell the difference.
Say you did absolutely nothing to the engine besides lower the compression by that amount, the car would still run same as before, it would just lose MAYBE 3-5hp, that's it.
Same with the cylinder head. As long as the camshaft is stock, the ECU will not be able to know that something is different. If the head is ported a little, it will change the flow but probably not enough for the ECU to freak out... especially at idle/low rpm.
