Can 400 whp be done and pass emissions sure, i do it every year
Youll just have to do some swapping here and there around that time, ie injectors ecu yadda yadda, pretty sure you can handle it...
Now as I can tell you from experience stock pistons ringlands will start to go around 14+ psi on a t3 frame turbo.
Obviously you know you'll need the supporting mods to do so, preferably not a turbo you have to run megaboost to make goals, less boost=less cyl pressure=less heat= less strain yadda yadda.
when converting to obd1 immobilizer is not an issue, its in your key, and around ignition switch, no removal needed. However you will have to convert 3wire-2wire IACV
Will the F23 head make 400whp stock, I believe it can an will.
Hope this helps..
Yes, thanks, now looks like this should be a pretty straight forward build.
So from what I understand you are running the stock F23 cam?
not to thread jack,^^^ but wont the car run like absolute **** after you put your factory ECU and injectors and stuff in?
This is actual a very common concern,I need to pass emissions and didn't think it was possible to build a block and do it..LEGALLY..ha
and again,sorry if i hijacked.
You have to:
1. Put the stock ECU back in
2. Convert everything back to OBD2
3. Put the stock injectors back in
4. Remove the spring from the wastegate so you don't build any boost
5. Put the cats/stock o2 sensors back on, etc
Then you should be ready to rock and roll to pass the inspection (correct me if I am forgetting anything)
You will need to drive your car like that for a few hours to make sure enough sensors are saying READY when they do the OBD2 test. If you don't then they just tell you that you need to drive your car and bring it back because there is not enough information. So just drive it slowly on some back roads, around a lake or something, no need to get on it.
I also don't see any problem with running a fully built/sleeved block and still passing emissions. Unless you are drastically changing the displacement and/or compression of your engine, the ECU shouldn't be able to tell the difference
